Wow. Never heard of bump charging. That's sweet
Any chance you could tell me what this bump charging is? I think my battery is draining too quick while I'm not even using my phone as well. I can't open the link because for some reason here at work they block it...
One technique that has gained popularity in the user community is "bump charging." To bump charge a device, turn it off completely, and plug it into a charger. Wait until the indicator light shows a full charge (on the ADR6300, for example, the charging LED changes from amber to green) but do not yet turn the device back on. Instead, disconnect and immediately reconnect the power cord. The device will now accept more charge before saying it is full. This disconnect/reconnect process can be repeated multiple times, each time squeezing just a little bit more into the battery. Does it work?
P.s. whats a "wake lock"?
I keep reading it...
