Battery first full day!
sudored
Member
13H 43M ON BATTERY.
Screen on time 2h 44m
still got 22% battery left mainly been web browsing and setting things up on my phone while out and about, 95% of the time on WiFi.
22 mins of phone calls and around 45 texts sent and received.
also regularly checked Facebook and twitter apps.
2ND day today
16h 36mins on battery
screen on 3h 49 m
14% battery left.
used about same as yesterday
20 mins of calls
50 texts sent and received
mainly web browsing
wifi 95% of time 5% 3g
Glad to see someone's getting good mileage on their nexus 4, gives me hope.
I got mine yesterday evening, and needed to recharge it by the time I went to bed. After charging all night it lasted all of 6 hours this morning, with only light use, installing a few programs and getting some directions..
It gets hot just being in my pocket, with the screen turned off and nothing special running. Hope it'll get better but I'm a bit worried now.
This is from my first full charge.
That sounds like a defective one.
When they get them back in stock you might want to go exchange it should not be getting hot sitting in your pocket
Yea I guess I might have to :( According to the Google return policy I have 15 days a to report and return a defective unit, I'll keep it a few days to make sure then maybe return it..
At least the N7 I got at the same time seems to be working fine. And apart from my battery issues it's an awesome phone!
It could just be a rogue app. Try factory resetting your phone and then updating it. If that fixes the problem then install apps little by little and see if you can isolate it.
If it is a hardware issue there's no telling how long it will take to get a replacement.
Day 3
Battery is getting better everyday!
15 mins of calls
web browsing.
facebook and twitter apps.
6% battery left
Day 3
15 mins of calls
web browsing.
6% battery left
Is there a way to enable a little battery percentage up at the top of the screen and have it show at all times?
Root and add in a battery mod. Once people get their hands on this phone custom ROMs will come out by the dozens.
I'm new to Android so I may not root right away. Plus at this rate I may never even get my Nexus 4 ;)
But is rooting really the only way to do something that simple?
You could always just get a battery widget. Not exactly what you were asking about, but it does what you want and there's no modding required.
Third time's the charm, got way better performance out of the battery this time around. Tried uploading the screenshots but the auto resize didn't work, so here are my stats:
16hrs32min on battery, display time on 1hr40min. Light use browsing, installing some apps and some Skype messaging.
Turned off the GPS but had WiFi on most of the time. I'm relieved :)
PS. I went running this morning, gave the phone to my girlfriend who was biking next to me so she could try filming a little. At the end of the run we realized the phone had slipped from her pocket! I took the bike and biked back to look for it, but no luck. On my way back I stopped people to ask for it, and the second couple I stopped had found it by the side of the road! What a relief!! :)
Battery life for my first full charge. You can see I didn’t have the screen on all that much as it was a busy day for me. Also spent some time in places without a great signal so that accounts for some discharge. The Belly app was using the GPS for like 4 hours for some reason so I’ll be uninstalling that most likely. Wasn’t a bad day as far as battery life goes I’d say but I’ll have much busier days than this so I’ll give an update after I see how those go.
You could try BatteryWidget?Reborn
Im on my second full day of charge with the phone right now. Yesterday was the first actual full day after getting it on Wednesday. I have to say I was very very happy with it. Normally I expect the battery to adapt for the first 3 days or so of usage, but it was great right off the bat.
With wifi, GPS and Bluetooth running the whole day and constant push from twitter and FB, I finally put my phone on the charger after 11 hours and 23 minutes. I still had 47% battery left. This is just about where I was with the Gnex running a custom ROM and kernal so I can only imagine how this phone will be in the future.
I rarely have a day that is long enough for me to kill the battery all the way, though I can't have a phone with me at work so that's a part of it. I'm still happy with the battery life on this device.
