Battery Fix
colonel51
I have tried XDA's root method for increasing battery life, and have gotten mixed results. I have also tried the non-root method of charging it all the way while it's on, then turning it off and letting it charge for another hour or so. As I usually charge my phone at night, this is very difficult. I have a solution which has been working like a charm for me. I use the app Reboot Manager/Widget from the market and it's amazing. I set it up to shut off the phone at 4:15 AM every morning. It almost doubles my battery life! It is the only app that I have purchased and it is DEFINITELY worth it. Try it out for yourself and post your results.
What was xda's root method for increasing battery life? If you are talking wiping your battery stats, this should not increase battery life, it should only give you a better indication of your battery's life;)
