S
Stroupified
Guest
How is everyone determining the % of the battery?
The HTC battery widget
Just spitballing here, but there have been mentions that the reported low signal strength is a software issue. If power is being boosted to compensate for the reported low signal strength, then it stands to reason that when the signal strength reporting is fixed battery life could improve as a result.
Good to hear. I get 20+ hours with heavy use.
and had to charge it more frequently. Today however was a different story...I just now plugged in to recharge after 20hrs with 22% battery left still. This is with wifi and blue tooth toggled off and everything else on.This simply cannot be stated enough apparently.
Any of your "personal experiences" under completely uncontrolled test conditions do not change FACTS. Just read a little, you'll learn something. Google it and skip any place that has "forum" in the name:
Charging lithium-ion batteries
"[FONT=Verdana, Arial, Helvetica, sans-serif]Lithium-ion is a very clean system and does not need priming as nickel-based batteries do. The 1st charge is no different to the 5th or the 50th charge. Stickers instructing to charge the battery for 8 hours or more for the first time may be a leftover from the nickel battery days."[/FONT]
I get about 20 hours with heavy use and 27 hours with light-medium use.
I LOVE my Incredible!!
Fair enough, but the "facts" in my situations were that I'd had all my phones for several weeks, prior to buying additional batteries for them. None of the new batteries, be it OEM or 3rd party, would last over 8-12 hrs while "idle"on my desk (work from home). As an engineer, I tend to be methodical about my evaluation process. I think I'd be able to factor in my usage in determining if it made a difference with a 2-3x gain in battery life. In no case did any purchased battery last as long as the original, on its first use.
I think I got a lemon
Discharging from 100%
Battery level 73%
37 Minutes since unplugged ( it was plugged in for 12 hours)
Android 65%
Display 22%
Cell Standby 13%
...Especially when there is available credible documentation that basically says what you think you are witnessing is pretty much physically impossible...
Android at 65% is awfully high I've never seen mine that high. In your battery settings when you click on "Android System" what is your "cpu total?"
CPU Total 33s
CPU foreground 3s
Data Sent 1.78 KB
Data Recieved 1.2 KB
I got the red light indicator yesterday after about 14 hrs. I'm on day 5 and it maybe has gotten a little better. That's really not going to cut it for me.
I just don't get how people say I need to turn everything off in order to get a long battery life. What the hell is the point of buying the phone then?
My blackberry had no problem staying charged for two days with heavy use, wi-fi, gps, internet, texting, emails, phone calls.
I don't buy that excuse that I have to turn all that crap off. The battery sucks, period. Why is everyone beating around the bush about it. It's an awesome phone, don't get me wrong, but the battery sucks.
What size screen and processor did your blackberry have?
My battery does not make it through the day and you get 20+ hours. Do you use any special power management settings? ThanksI get about 20 hours with heavy use and 27 hours with light-medium use.
