battery getting hot
libai8268
I notice this recently. I only play around with market, and download some apps occasionally, it somehow got really hot around the kickstand. Does anyone feel the same way? the battery is getting pretty hot?
You can download battery status pro and it has a symbol on the status bar and when you drop the notification bar down it shows the temp of your battery.
Hope I explained that correctly.
