Battery hard to remove?
Hawk375
Anyone else finding the battery difficult to remove? I literally have use something to pry the battery out of the phone. When installing the battery, the top of the phone seems to tightly snap onto the battery instead of just sliding in and out.
It's tight but not overly so.... On the top where there's a slit/fingernail slot, you need to push down towards the bottom of the phone and then it just pops off.
seems like my battery just fits in tighter than it should, it audibly clicks into place at the top of the battery
Out of curiosity, why are you removing your battery? I pretty much installed mine, and it's been in the phone since day one.
Oh OK cool, I was wondering if there was some kind of problem you were experiencing that was requiring you to "cold start" the phone! My Captivate had a shutdown a few times where I had to pull the battery.
