Accessories Battery help need one NOW!
AFGixxeR
Member
As the title states I have to buy a battery today or ASAP. The one I have just doesn't stay charged and it gets hot which resets the phone, very annoying.
After reading several threads in the accessories I think I've decided between the 2 battery 1800mah combo with charger from htcexpress or the one from bidalles on ebay. Which one should I get? I know I don't want an extended that won't fit under the phone's battery door. Please help me decide soon, also if you could tell me the proper way to charge it when I get it to get the optimium performance that would be helpful.
I've tried both and only use the one from bidalles. My experience has been that the 1500 HTC battery gives me the life i need to get through the day. The two batteries from HTC Express lasted the same for me as the OEM, just gave me the option to swap batteries; something I did not want to do.
Just my 2 cents.
