Root Battery icon.
prj
I currently have one of the Froyo ROMs installed. What file or files do I need to change out so I can have a different battery icon in the status bar?
Here's a battery icon pack I made, it's based on one posted to XDA(I can't seem to fine the link) but repackaged for the eris. You can unzip it to see where the icons should go. This works with Metamorph and nonsensikal.
Will it work with xtrROM 4.6?
You'll need to install metamorph, it's in the market. Put the zip on you're sd card, start metamorph start checks and choose unzip then click the battery2.zip. Then click pick existing theme-battery2-battery2-battery2.xml.
You may need to restart you're phone for it to work. You can do a Nandroid backup if you're worried.
