Help Battery icon
funnyzach
When i got my Epic 4g, You know how the battery icon is horizontal? Because when i first opened my Epic 4g, My battery was horizontal and was colored blue. (probobaly like you guys) But once i finshed charging, it turned vertical and green, like the charging icon except with the thunder across it. Can anybody help? It's frustrating for me because i can't see the battery life above 70 or 80%
Yep it's part of the update - I like the Gingerbread update, and I use an actual battery widget (I highly recommend getting a widget if you don't like the new update) instead that way I always know my exact percentage :)
