Help battery ICS
1981
Hey guys, would appreciate if someone cud clarify .
After my recent ICS upgrade, my S2 battery seems sluggish in getting charged. Have anyone noticed similar issue. Before the upgrade, while charging ,one HR of charging would gain approx 40% charge. But now its sluggish. Its just around 25-30%at the most, after an hour of charging. I tried removing the battery for about 10MTS to see there is any change. But unfortunately not. Please advise. Thank you.
It is not unusual, after updating firmware, for the fuel guage to mis-read the battery/charging levels. This will settle down after a few cycles. Unlike some other Android phones, the SGSII does not respond to the battery calibration app's on the Play Store and therefore, to hasten the re-alignment of the phone's fuel guage, I would recommend this procedure, here.
Failing that, you may have an app or data that is causing problems after the update and you may want to consider a Factory reset.
