Battery % in status bar like the ICS have
Alpejohn
Hi,
I got an update to my Galaxy S2 4.0.3 that enabled me to have battery % on the side of the stock battery icon in the status bar.
I now have rooted my phone again and installed a custom rom (Im now using this: Resurrection ICS ROM v.2.5.3 for Galaxy S2 i9100! [Jelly Bean Transitions][Best ROM] | Galaxy S2 Root )
Im very satisfied with the rom, but i really miss the battery % that i had in the stock android 4.0.3 before i rooted..
Is there a way go get this back? I don't want to go back to using widgets on the home screen :( And i don't want one that is to the left of the status bar.. :)
Is this possible? :)
Regards
Fredrik
Not tried that one. Is it the AOKP rom by westcrip? Should have rom control in settings if it is that one and from there options for battery styles to show percentage.
Oh, i checked the rom control, and found a setting for battery, where i could chose only text, picture, and so on! Looks like its fixed! :D Thanks for your tip! :D
