Root Battery indicator by percentage - 99%
Taylored
I have searched everywhere for a zip that will change the battery indicator to a percentage. Anyone have any ideas or zips?
Stock battery meter on the top bar can't be replaced or modified without root. Even with root, we're still waiting on a modified battery meter to be ported over for the Inc.
just a fyi.. the more polling you do to the battery with a meter, the quicker it will drain your battery..
Thats why most phones go down in 10% increments.
I am aware of the restraints in implementing the change and issues that may arise. I am just asking for a zip or an existing ROM I could pull it from.
Thank you for your thoughts.
With CyanogenMod-6 you can change the battery icon to show you a %. Thats how I have mine setup. I don't know if this is something you could extract and make work on another Rom.
yup, that's what I'm doing. you can even choose the color of the font! :D
I did not find anything in spare parts. I was going to sit down this evening and just try to make my own, but I played starcraft2 for 4 hours instead. :)
