Help Battery Indicator on Lockscreen
trembly01
can someone please tell me which app or widget to get that will display my battery info on my lockscreen........my phone is rooted and i currently am using batterylife which i like but i don't know if there is a better option plus i wanna put it on my lockscreen so i don't have to unlock my phone all the time
WHat you might need is a transparent lock screen. Can you see your notification bar when screen is locked?
If so,try an app called Battery Status. It will put a battery percentage on your notification bar.
If you cant see the bar, search your all things root section for a theme that includes a transparent lockscreen
