Battery indicator power on off bug?
Durtydawg
Hello all new to the Atrix but not droid, Aria for awhile, then Captivate, died on me first thirty days ATT talked me into switching to the Crapple Iphone which I just thankfully was able to get rid of and now am back on droid thank God.
Anyway enough with the background, I was wondering if anyone else is noticing if when you battery indicator turns orange and you power the phone off and back on it goes to 50%? I have tried this 4 times now and it has worked every time. I was actually concerned the battery life was horrible in this phone but after I power off and on I get several more hours until indicator turns orange for a second time. So is this a software bug? Is it only my phone and I need to return it for new?
Thanks for reading.
Ok thank you last night shortly after my post the indicator turned orange and I powered it off, plugged it into my charger and it showed battery at 60%
Tonight right before this reply battery showed orange powered off and back on 60%. Now trying to decide rather to return it for new phone or just grab battery widget off the market.
mine does this too after the GB update. with Battery Monitor Widget I can see that the battery voltage didn't change, as expected, but the % available spikes up. usually it increases by 15-20%.
