Actually that's not correct. Although hit hits 100% and stops charging it will automatically start charging again once it hits a certain percentage. Somewhere in the 90s. So its better to just leave it on the charger, imo, until you're ready to start using it. No point unplugging it just because it reaches 100% and you AREN'T going to use it. You'll get the same amount of battery drain whether its on the charger or not at that point.You should have the same amount in either case. The evo stops charging and runs on battery power only once the battery hits 100% that's why you get that instant battery drop when you unplug it. Weather its plugged in or not its running on the battery in both cases.
Geez. You guys took the fun out of it. I was really looking forward to hearing Slick try to weasel his way out of this one.
You are causing the confusion. You have yet to explain why you must unplug it as soon as the light turns green.
Here are 2 scenarios that I would love you to explain:
I plug in my phone at midnight and the light turns green at 2 a.m. I don't need my phone at all until 8 a.m. when I wake up.
1. I unplug the phone right at 2 a.m. and let it sit on the dresser until 8 a.m.
2. I keep it plugged in until 8 a.m. at which point I take it off the charger.
After using the phone for 1 hour (it is now 9 a.m.), which scenario will leave you with the most remaining battery life?
I may be mistaken (probably am). But if I take my phone off the charger when it hits green, let's say that is right before bed, when I wake up I am only down 2 %. When I charge overnight, when I get the phone, it says 100% but drops to 90% really fast (checking email, FB, news) . The charger-to-full before bed scenario, I drop maybe 3 % max. I leave the house with 95% charge one way, 90% the other.
Just me experience.
I have been using this app since I got my phone in june. Why insult people when you don't know what your taking about? Drop down the status bar and click on the batty app. Now a pop up comes up. Now press menu. Now go to settings then time settings. If you look you can set the discharge time for light, moderate, heavy, constant usages. You set the value anywhere from 45min to 98 hours. How does me setting a time value tell me when the battery will die. I could set it for 50 hours heavy usage but I'm not going to get it. You might want to look st what someone is talking about before insulting them.
I don't think your battery will discharge any faster whether its plugged in or not. So the drop should be the same. I would think it would be better if it stayed plugged in. When it reaches a certain percentage while plugged in, it will start charging again.
And 2-3% drop in 6-8hrs? C'mon son...
My battery is cold in the mornings
"Here is a list of myths, which could very well all be wrong because I may have understood them incorrectly."Disclaimer! The facts presented are subjected to the best understanding of the author, and might not be entirely accurate. For most accurate information, please consult your device’s manual.
