sharksfan7
An odd issue has popped up for me in the past few days. I have a widget on my home screen that brings up the Battery Use screen and it no longer seems to be updating properly. If I bring up the screen and note the time on battery then come back later, the time will not have changed. Hitting refresh won't update it. If I go to Settings>About phone>Battery>Battery Use, the time on battery is accurate. It's only when I access the info through a widget on the home screen that it's wrong.
I've tried two different battery widgets and the same issue happens with both. I tried deleting the widgets and adding them again. I've uninstalled the widget apps and reinstalled them. I tried clearing the data for each widget app. The issue still persists.
It would seem the widgets are just a shortcut to Settings>About phone>Battery>Battery Use, but for some reason they are accessing old data. Has anyone else experienced this? Any ideas on how to resolve it?
