ImperialJohn
Does anyone recognise the symptoms of what is wrong with my phone?
I used my phone a few days ago at work, took it out of airplane mode as I always keep it in this mode when its in my pocket. Full battery. Listening to 5 minutes of TuneIn Radio while reading tweets and a quick check on FB notifications to see what family are up to.
Then all of a sudden alert on screen saying 5% or less of battery remaining. So had to exit everything and shut down as it would have done this anyway after a couple of minutes.
Then later on in the day I was taking a quick break, I decide to try turning my phone back on. It comes on! So I go into the setting to check phone status, and under battery it has 89% of power remaining!
What gives?
Is this a fault with the battery or phone? Or both?
I am experiencing the same situation all the time in that it runs out of power very quickly. After only 20 minutes max of being unplugged which is dreadful.
Do I just need to replace the battery and if so, can I get one with a battery capacity that wont die on me after only two years?
I have a Motorola Defy Running Android 2.3
What gives?
