Help Battery issues help
nizmoz
My battery life on my note has been fine till the past week. Now its draining fast and I am unsure why. Nothing changed and I barely used it today. I am usually at 80 % by this time and I have only 50% left now. See these screenshots and let me know what I can do!
Thanks.
Useless site.
This is not a useless site but post saying it is will make it hard to get help. Posting that kind of attitude after just 39 hours will not help you get answers especially since that is during a weekend and you didn't give much in the way of information.
Now to help you I would like to know if you have added any software or changed your settings for sound, vibration or data? Could you post an image of your data usage? What do the icons that show in your status bar represent? I know some of them but others I am not familiar with.
Comparing your screen with mine I see you have used 3% more screen time, 12% less Android System, 19 % more Voice Calls, 17 % Android Core Apps, 4 % more Device Idle and 9 % Cell Standby.
I don't have any Cell Standby, Voice Calls or Android Core Apps showing on my T-mobile Note 2 and that accounts for 45 % of your usage of your 101% while My phone adds up to only 96% your post shows almost twice the usage of my phone.
I think you need to find out what accounts for the Android Core Apps and why you have a 19% of your usage for Cell Standby.
This site has also been down several times over the weekend, hence no way for anyone to post a reply to help you. Patience is a virtue!
