Battery left widget
vicshalls
Not just with this widget but any battery one how do you know if it is working right? Which one have yall found to be the best battery widget?
I like battery indicator best. I used Battery left for a while on my samsung moment and for about 2 weeks on my black Evo.
Woefully inaccurate.
I also use battery indicator.100% accurate on my evo. I know its accurate because when I plug it .in to charge, it shows the percentage when you go to your clock. Battery Indicator always matches.
I use a widget called Mini Info...battery % always seems to be accurate and it also shows me available ROM and RAM.
It might be just a coincidence but after upgrading to 2.2 (the officially not official version) my battery life tanked. I un-installed Battery Left & it seems like its back to normal. I switched to Battery Indicator.
I agree. It doesn't drain the battery more to run it on the taskbar and the percentages are spot on.
"Battery Indicator" - FTW (IMO).
