Battery left widget
jaybo1973
Android Expert
Hi all
This may be one for the apps forum, but maybe it is a desire issue?
I recently installed the battery left widget after lots of people having it on the 'show us your homescreen' thread. The widget is now 100% accurate (or so it says). It is 20% different to the system reading though. (widget 33% system 53% at time of writing) Anyone else having this issue?
I run Battery Left & Mini Info & there is usually a 3% or 4% difference between the two.
Mini Info gives you the same as the system reading.
Which is more accurate though I don't know.
I was out until my phone died last night. they came together near the end. Odd how the widget shows system percentage in the settings correctly
