Help Battery level on notification bar?
politzer
Does anyone know of a setting or widget that will display the battery level on the notification bar? Hopefully next to the clock and network levels?
Thanks
Thanks
There are a lot of them in the market, but they are on the left hand side of the notification bar. If you're rooted of course it can be done as you ask
