Pull down your notification bar from the top of your screen, then select quick settings. All of the different radios will appear (3G = mobile network, 4G, bluetooth, WiFi, Hotspot, etc). Make sure the 3G/mobile network box isn't selected with a green check mark.
Yes, you can still make calls and receive text messages without 3G, 4G, or WiFi on. But if you want to download voicemail to your phone you will need to have one of those radio selected meaning turned on by using the quick settings tab in your notification bar.
If you have a weather app that's allowed to update every hour and it pulls a lot of data its going to consume a lot of battery power. Especially if you are in a poor 3G or 4G area. If you are near WiFi, use WiFi whenever possible.
I would have to disagree with the live wallpaper analogy. I run a live wallpaper and I think it doesn't affect battery life with the EVO 3D. As I stated before, I go under Menu - Settings - Power - deselect the box titled power efficiency. My battery idles better since I'm in a some what bad coverage area in my hotel. I think I do a better job than the phone of managing the "device network" than that power saver setting. Can you guys deselect that box and see if your phones idle better too? Then again I leave all of my radios off.
