KA24DERACER
KA24DERACER - What version of JD are you using (beta, free, pro), whats your setup in there and how long is your battery normally lasting with these tips you just suggested?
I use Pro with the Advanced settings as follows:
Controls: Data, Wifi (Auto Disable), AutoSync (Ping mode) <-- all standard
Schedules: 15min <-- slightly more often than standard
Triggers: Battery (5%), Screen, Traffic (10Kb/15sec), 15sec/min <-- everything slightly lower than standard, since I keep my 4G antenna off unless I need it and Metros 3G is sometimes unable to keep enough data going to keep Data enabled
Apps: Enable/Screen Off: Google Play < -- JUST in case I am downloading an app or update this keeps Data on FOR SURE when Google Play is up on the screen even if it turns off (this is why I got Pro)
On just idle I get around 2.0X - 2.5X battery life with both my phones. If I use it any more than occasionally, then on my Optimus M I get around 1.5X - 1.75X, and on the connect I get around 1.5X (which makes sense as I have an overclock running and the connect is a MUCH more powerful phone than my old Optimus)
As for you, you can do everything I do except the App Control with the Free version, but I was willing to pay the $1.99 for the extra controls (there are more I just havent messed with them yet as these work pretty damn well for me)
EDIT: As for TIME in battery life, Ive seen as high as about 10-11 hours on pretty much standby the whole time. Im running another test right now ill report back in a while with the results but as of right now (4 hours on almost all standby with 75% battery remaining) its looking like about 12 hours total.
