I personally use battery indicator pro,it sits in the task bar and gives you a percentage of battery power left and also you can set when the icon changes to green,yellow and red.
I use Mini Info. It indicates remaining battery life in 1% steps, remaining available internal memory and remaining micro SD card memory in one handy 2x1 widget.
I.don't like any of the status bar based indicators. Personally use battery Droid as I find no drain where I have with.pretty much everything I've tried.
