that's not what that means...
o ok lol i was confused at first.
I did this last night and it has made a major difference on my battery life. Just make sure you backup your information using Lookout or Titanium Backup (both are available in the market). Then go to menu> settings> privacy> factory data reset.
you have to re-download all your apps then though, right?
Yes you do. Just use Appbrain and create a list of the apps you have installed. Then after the restore, reinstall Appbrain, login and all your apps will be listed for you to reinstall.
okay. a few more questions.
the pics and vids i've taken with the evo, they are stored on the sd card in the phone, right? will a factory reset wipe them from the card? do i need to take the card out before the reset?
i'm only getting about 8-10 hrs from my phone with all the settings adjusted and VERY light use.
I unplugged my phone an hour ago from the charger and I had 4G on for a few minutes, surfed a few pages, and am now at 86%. THERE IS A BATTERY ISSUE. Heck, with all the radios off I went from 100% to almost 90% in minutes.
How do you turn off all the radios? My god doing that and using ATK the batttery should last for a damn long time.
