Help battery life just got worse?
newjacksm
Member
About 2 days ago I noticed my battery would drain down to about 40 percent after about 2 hours of just texting through google voice app. this is really unacceptable.
I also started using a samsung charger that fit this phone, the samsung charger was for a cheaper phone that wasn't a smart phone I figured it was ok to use, but I dont think that is the problem.
Anyone have an idea what it could be? I have installed any apps other than updating apps.
Have you power-cycled and pulled the battery?
On at least two occasions my Incredible has gone a bit crazy and drained a full battery in about 4 hours of non-use. In each case, once I realized there was a problem I pulled the battery. After restarting it's always been OK.
It hasn't happened since I started using SystemPanel so I'm not sure what caused it, but I suspect it was a runaway app that was continuously refreshing even when my phone should have been in standby.
Check this thread. http://androidforums.com/htc-incredible/239103-some-recent-update-killin-my-battery.html
People are saying that since they updated the facebook app it has been causing very fast battery drainage. It might be due to that.
