Hi didi :hello: Even if you are not on it much, it kind of depends on what you're doing when you are on it. I hardly use mine at all when at work. When I get home after about 9 hours, I usually have around 75% charge left on it. If I'm surfing a lot or watching videos I can easily use 10-20% an hour.
Which android version are you using? ICS 4.0.4 seems to have a little better battery life. Also, take a look at this thread. Its tips for non-rooted phones but still applies even if your rooted.
How do I know which version it is? What does non-rooted mean? I did update the camera. It was horrendous. Clarity just terrible.
Says 4.0.4
Is it necessary to get rooted right away? Or only if you have an issue?
