Battery life post ICS update?
gagglone
How is your battery life, post ICS update? Mine seems a little low(I have the MAXX). Before the update, I could get to work(at 8am) and be at 60% by 4 or 5pm that day, now it seems like I get to work and I'm down to 50% by noon. My phone use habits has not changed(general texting/checking emails/browsing the internet when I go outside with buddies to smoke).
Thoughts?
right after it downloaded, terrible. phone was super hot as well.
did a power off, wait, power on.
since then, 3 days now, it has been fantastic! amazing!
Since i did the ics update my battery hasn't changed at all. I was rooted then flashed back to stock sand installed ics and yesterday worked a 10hr day and had 4 h r of screen on time while i surfed the Web and f l i p b o a r d. Used Facebook and anything else i wanted. Got 1 2 h r of battery out of it.. All this while on 4 g
I see you're using s w i p e.
It will usually take a couple of power cycles to get accurate battery stats again after an OS update or factory reset. The internal battery stats typically get wiped when the update/reset occurs. Until the dust settles you are likely to greater or lower battery life as the OS learns how the phone is being used again.
mine was horrible the first couple days after ICS...now it is phenomenal, i am right now at 83% after six hours and i had a 45 minute phone call and a bunch of texting and facebooking in there
After the update my phone is stating the my screen is taking up 77 % of my battery although i am not using it any differently than GB. Any thoughts?
Glad to hear the battery life gets better! I just got ICS update like 3 days ago and noticed my battery life isn't all that great... although I've had it today on for 4hrs and it's at 80%... is that good? lol
Alright. I have a droid razr. This update has royally screwed me over. My phone can't live more than like 5-6 hours now. I used to have problems with gingerbread but they released an update for gingerbread a while back that doubled my battery life to about 16-20 hours of regular use. Now that I got the ICS update it's back down to like 5. I don't understand why. I use a battery saving app called juice defender. My phone also charges REALLY slow, and gets REALLY hot. I was using a 5 amp charger to charge it and it soaked up ALL 5 amps in a few hours and still wasn't fully charged. I just don't understand how it can be this much worse. It's making my life much more difficult when my phone can't even stay charged when all it does is sit in my pocket...
Take a look at Settings > Battery
It will look something like this:
From here you can see which apps are using the most of your battery. Touching each will let you know the amount of time the screen is on or how long your voice calls have been along with other information.
You can see the app Sleepy Time on mine and that it used 4% of my battery power so far. That is because I had it running for about 4 hours last night when I went to bed. Anything that is using a lot of your battery will show up here. This area can help you figure out what is killing the battery.
If you touch the top part with the graph it will give you a better view of it:
From here you can see the quality of your cell reception (green is good, yellow is ok and red it bad), GPS, Wifi and screen usage. You can also see the times you have been on the charger. This should be able to help you see when during the day your battery started to be used more.
I have not had a lot of experience with juice defender, but I do remember it giving some people grief on the Galaxy Nexus with ICS. You may want to poke around in that forum and see what the problems were.
You also have to remember that things run a bit differently with ICS overall. You have the recently used app list and some of those may not shut down properly so it is always a good idea to swipe them off the screen when you are done. Long press on the home key brings up this list.
Another place to look is in Settings > Data Usage.
This may give you an idea of any apps that are using a large amount of data. Large amounts of data being used may also lead to larger uses of the battery.
In the end, overall battery consumption is caused by the normal things most of the time. The screen, cell network and reception (bad reception uses more battery), leaving apps running (always use the back button to exit apps), etc.
There are also things that will help you conserve battery life like using wifi when available, setting the screen brightness lower (around 30 or 40 is good), turning off data when not in use or in a bad signal area, switching to 3G only when there is no 4G in your area, etc.
Hope that helps.
Mine was good under GB, it is incredible now. I'm at 59 hours since my last charge and my battery is still at 50%. I'm thinking I may now go 4 days between charges.
A little better...temp seems to be running hotter for me
Same here, but if running hotter, must also be using more battery.
Games and even web browsing are definitely hotter and battery life taking a hit.
On the flip side, performance is smoother and no data drops in over a week since updating.
Sleep time is just as great as before the update, but clock usage appears to stay at full clock a lot more, hence the additional heat and battery life hit.
Sleep time is just as great as before the update, but steak usage appears to stay at full clock a lot more, hence the additional heat and battery life hit.
Same here..
Screen taking up a higher percentage though even though my usage hasn't really changed.
Also running hotter.
Much smoother though, like flipping the phone from portrait to landscape is instantaneous for example.
I have been Swyped. Meant stock instead of steak in my earlier post. Frankly, if I had the Maxx I would not mind the battery hit, but in spite of the improved performance, I would rather go back to GB and Launcher Pro using the thin. Added: Not the preferred option, since ICS is better than GB.
I stick by the review update I posted, but after using over a week, the battery hit and the heat are offsetting the good stuff.
If this is what it is, I would keep the radio update and bail from ICS. Maxx has more room to take the hit.
For people that are light users, the thin and ICS still rock. Heavier users though will probably notice the hit.
Screen shot or it didnt happen..:eek:..congrats
Haven't done this before. Here's an attempt. 74.6 hours and 40% battery remaining. It hasn't been anywhere near a charger over this time.
I think I'm going to get to 4 days easily.
Click on image to enlarge.
Nice. No background data? Twitter, Facebook, Flipbook, etc? I need to try CDMA and see what kind odd life i get, cuz i get around 18 hours on a charge.but that's also several hours of screen on.
