D
Deleted User
Guest
No difference for me on 4G. Much better if I just leave it on 3G.
As I posted earlier, I am getting HORRIBLE battery life on my Razr thin. I had GREAT battery life before. I am now getting 50% after about 4 hrs, when it use to be more like 12 hrs or more before it got down to 50%. I am using Smart Actions just like before where when the screen goes off, data and sync wifi are shut down..still with the update it isn't doing anything.
I did do a factory reset the other day and it still is crap and I am using the phone the same as before the update. My screen usage % before the update was low 30's to high 30's, never over 40. It is now upper 60's, 70's and even low 80's.
Please, any suggestions????? I am at a loss!!
yeah, I did the FDR yesterday and I am still draining pretty fast. Wasn't ICS supposed to drastically IMPROVE battery life? Between this forum and Moto's forum, battery life seems to be a big issue.
Moto will most likely release a patch that fixes the battery. I remember something similar with the X2.. enough people complained about the hit to battery life when they upgraded to GB and like 3 or 4 weeks later Moto released an update that fixed it.
I applied my upgrade on Tuesday of this week, and since then, my battery life has decreased.Do you keep wifi on all the time? A few posts back I mentioned the possibility that it might have something to do with that. I've had my wifi off now for a couple of hours and have seen an improvement, although it's still too early to be sure.
I just checked the wireless settings and it had 'notify when protected network is available' enabled. I disabled that feature.
I keep Wifi turned on all the time. I have a smart action set for my home and when it detects my home's wifi, it turns off cellular data, gps and bluetooth.
One thing I noticed was that I was getting constant 'alerts' of available wifi networks, something I didn't get previously. I just checked the wireless settings and it had 'notify when protected network is available' enabled. I disabled that feature.
I think its constant refreshing of available networks was helping to drain the battery. After another day or two, we'll see if that was the major culprit for my additional battery drain.
I had turned that off a few days ago. It didn't help. So far totally turning off wifi looks like it's made a big difference.
If i were you i would try flashing the kernel from the new.214 leak.
Do you keep your wifi on? I'm starting to think that may be an issue (see my post from earlier this morning). I've had mine off for a couple of hours and it seems to have made a difference although it's still too early to be sure.
How do I do that? Not to tech savy!
