I'm not sure how to turn gps off and do you know how to delete the applications that came with the phone? Like gps and slacker
I got Tmo to swap my Behold II for the Vibrant.off topic sorry
hey yatimahakddaidoamiji,
i see you abandoned the behold deuce and are over in this forum now. good to see your still around
I highly recommend you install the Power Control shortcut bar, it's very easy and then you can disable all the more draining services affecting your battery.
To use the Power Control shortcut bar:1. From the Home screen, touch
and hold an empty area until
the Add to Home screen menu
displays.
2. Touch Android Widgets ➔ Power
Control. The Power Control
shortcut is added to the second
panel of the Home screen.
3. Touch one of the icons on the
Power Control shortcut bar to
activate the application. A green bar displayed beneath the
icon means the application was activated (turned on).
4. Touch one of the icons a second time to deactivate the
application. The green bar is removed from beneath the
icon which means the application was deactivated
(turned off).
Where can I download this at I don't see it on market
It's built into the phone. You'll find it if you long press a blank space on the home screen, then when the menu pops up hit Android Widgets.
You might even just want to pick up a spare battery. At $3.19 delivered they're cheap enough even if you only use them once a year!
1500MAH OEM BATTERY FOR SAMSUNG I9000 GALAXY S NEW - eBay (item 280546973427 end time Sep-09-10 07:01:41 PDT)![]()
Once the gps gets fixed, I'll buy my first app, Locale. I remember when it was free and it was an awesome app, until it would cause the Behold II to reboot lol, the good ol' days
doode, my buddy has got the vibrant and was complaining about the GPS, i took a look and it was just a tad slower to lock on the the behold.
so the GPS cant be that much worse than the beholds GPS slowness can it?
I am a new android user and on I have had my phone for a week now and the battery is still the same. its pretty bad for my liking. this what i had running. twitter widget updating evert 5 mins. a facebook widget updating every 30 mins. a pandora widget. live wallpaper screen timeout 15 secs. screen at its dimmest all the time. ohh and facebook wasnt always log on but for the most part it was. twitter was always logged on i never have bluetooth,gps,or wifi on and i got about 5 1/2 hours with this. i want to know if this is just me using the phone way too much to expect better stuff or if it is just my battery and if you are getting way better battery explain what you have running it would really help me out.
now i have mad some changes to what i do but i still dont get much more battery and to me it feels like it is taking away from the android experience that i have in my head haha. i am new to android so please take it easy on me.
