Did you guys find a way to make battery life better? Also how is the wireless tethering going?
I just wanted to say that now that i have removed bloat, i went back to using the Blur app drawer. Its quite sexy without bloat. Still using LPP as my home though.
Edit-
Oh yeah. 75% after 11 hours =]
Edit-
I wish I could have this kind of battery life. What exactly did you remove and do to get this kind of life from your battery?
Right now there is no recovery, roms or kernals(no overclocking)to flash. Just download Titanium Backup/Titanium Backup Pro, Root Explorer and Setcpu from the market. TB will allow you to backup apps and system data. It will also let you uninstall/freeze apps and bloatware. Root Explorer will give you access to system files and sdcard. Setcpu will allow you to underclock and set battery saving profiles.
I hope that helps.
Post root report:
1. For battery, not much difference if any, but was already getting good battery life.
2. The auto run apps appear to be placebos and do not seem to really do anything besides cause more polling for that app to try and stop other apps. Thing is, the auto apps I tried (and noted in the thread) do not stop any of the apps listed as disabled. Not one of them. I would call it snake oil sales, but the apps are free.
Nice to have Titanium back!![]()
I beg to differ. Autoruns works as stated, you must not be using it right or not have used it ady all. It doesn't even poll, it is similar to a registry editor on windows and edits the trigger rules that enable apps to turn on. I'm a fresh freak about what's running on my phone. It definitely works and does effectively stop 95% of the apps you disable. I have found that dlna service is tricky to disable, and one other service, camscan. I believe there are unknown triggers as the app itself hides things it doesn't understand, but you can view those as well but those are more complicated to mess with. If you it have questions on that app is be happy to help, I've used it on my 2 of my rooted eris, 1 rooted fascinate, 1 rooted incredible and now 2 D3s, and the majority of the apps I've disabled won't turn on without being manually called upon. The trick is not just setting the autosatart setting but all the other triggers. View it by app, that's you optimal setting. You`ll thank me later if you go back and mess with it.
Oh last thing, autoruns is NOT a task killer so it isn't always running its a one time set it and never look back. And it doesn't turn on again unless you install or update an app and go back to check the settimgs again. Some updated apps do reset their auto run triggers. Do keep that in mind.
Maybe the problems is the app being used, since as posted above, the version I was using is not called autoruns. You keep wording the same exact way, so is there an app called autoruns?
BTW, not sure Android can behave in the manner you suggest and keep apps out of the registry stack all the time, since if the apps are being controlled that way, they will become part of the active eco-system once you use one of the apps (how could it manage once they are opened, unless it was polling?). Any listing of the script commands so I can see the process? I will halfway understand it
Thanks
Sorry, it's called autostarts.my bad!
Since we now have root, how can I shut off "DDRROID" that plays on start up?
