I live in a 4G area and I can leave my phone sit idle while doing a couple texts etc for about 30 hours. Now if I play games the battery drops like a rock!!! I guess thats to be expected running a dual core phone.
NOTE: I'm using the standard battery becasue my extended battery only gets 12 hours with the same condiontions .
i've gotten over 50 hours with the standard battery with about 3.5 hours of screen on time.
Is it 30 hours idle in 4G? That's unbelievable. Even with 3G/WiFi, sitting idle in good signal area, getting over 30 hours seems tough.
Mine seems to drain about 8~9% per hour sitting idle in 4G, and I'm in medium 4G area with speed ~ 6~8Mbps. That equates to about 11~12 hours total.
Are you serious? Maybe someone put Razr Maxx 3300mAh battery in your Gnex?This is what I usually get with the extended battery, around 11 to 12 hours total with around 2 hours screen time. That doesn't seem to be what we should be seeing using an extended battery.
edit: that's insane really if it's on 4G. maybe you are using app like juice defender?
The extended battery is 15% bigger than the stock battery. Nobody seems to be understanding this.
Just because it says "extended" doesn't mean it automatically has a huge amount of juice. It's a tiny bit bigger, so it's only a tiny bit better.
With LeanKernel installed, it appears that my phone drops a couple % per hour when it's idle - that's it. I didn't play much with my phone today (a couple phone calls, a few text messages, checked the weather and twitter a couple times). It has currently been on for 10h 30m, screen on for 31m, and I'm at 76% battery life. That is well over 30 hours of battery with this kind of usage (i.e. not just idle, but very low usage).
Also, I leave Wifi, GPS, Bluetooth and 4G on all the time.
I'd be thrilled with 11-12 hours...like the OP, I'm lucky to get 5-6 hours.
If that's the best you get with 3G/WiFi, I wonder if yours or battery is defective. Is there any suspect app or have you tried factory reset? If nothing works, you better try to exchange.
I think I may be on to something...I'm at 57% after 6 1/2 hours...by far the best I've seen in 3 weeks that I've owned it. I left Wifi on all day, downloaded Juice Defender and dropped screen brightness down to 20%.
This may take care of my battery issues for the most part, but still leaves my reception in question. I'm at 79% time without a signal today. I can still make decent quality phone calls at -110 to -120 dB signal, but have absolutely not 3G data.
I thought my battery issues were related to my signal (or lack thereof), but that seems to be largely debunked. That's good news, but doesn't make my decision of whether or not to swap for a Razr any easier...
I would definitely try and get a new phone or flash a custom ROM and/or kernel. I am using Liquid's ROM and Minimalist kernel. I get around 10 hours of battery life with very heavy use. The pics I posted are of light to moderate use as you can see. I still have 48% left in the pics.![]()
Here's mine. It may not look like much, but it's the best I've seen so far![]()
So the question is, what were you doing last with the phone? Your screen was on, and your battery percentage crashed what looks to be almost 40% in a short period of time.
Playing a game?
jkc- I thought that if you had Wifi on data was disabled, but maybe I'm wrong. If the data is the problem, I suggest getting an NFC tag for the spot where you leave your phone, and you can set it to disable or toggle your data.
I definitely get more than that. I'm in a 4G area at work, with 4G turned on all the time, no Wifi, screen brightness on auto. On standby, I drain maybe 4% or so an hour. I've been getting maybe 4.5 hours of on-screen time (unless I'm playing Pocket Frogs for a long time, seems to be a big drain there) and definitely more than 11-12 hours on standby. If I use my phone normally during the day (as in, I don't stream music over BT all day which is obviously different), I go from 8 am til 6 pm or so and usually come home with at least 40% left.
