Battery life terrible since flashing latest modaco rom :(
ripkord
Member
As the title really - for example full charge last night about 1am, currntly sitting at 58% :/ would last a few days before flashing :( I'm not running anything differently - everything thats switched on was switched on before if you know what I mean! Is there anything I can do? Apart from going back to the previous (very slow in comparison) ROM.
I have taskpanel installed to auto kill pretty much everything apart from the UI and messages.
I am running 3.1 and battery life seems as before.
As above, drop the taskiller. I haven't used one for ages.
If you are still struggling with lag I would recommend a wipe. I wiped and reflashed 3.1 for an unrelated issue and subsequent RAM usage was noticeably improved.
Try systray monitor which uses much less memory to run than the taskiller/panels.
