boteman
Member
A good source of battery information is the web site of a battery rebuilder.
Although you might think these guys just want to sell you something, this article basically tells you why they can't rebuild Lithium-Ion batteries and it quells a number of misconceptions.
What about rebuilding Li-Ion batteries ?
Basically, Li-ion batteries are born to die and start to deteriorate the second they leave the production line. I don't know that charging methods will change that very much, but I did Google an article that explains the technical considerations and shows the life span of a number of smartphone batteries.
How to Prolong Lithium-based Batteries – Battery University
Also, because the battery pack includes control circuitry I don't think the phone sees the actual charge state of the cells, but rather a window into a portion of their capacity. The Prius battery indicator is like this, so when you see the battery indicate full charge it's really only at about 65-70% of its actual cell capacity for example.
Deeper discharge cycles shorten the life of the battery, so beware.
Hope this helps.
[FONT=Arial, Helvetica, sans-serif]The smaller the depth of discharge, the longer the battery will last. If at all possible, avoid frequent full discharges and charge more often between uses. If full discharges cannot be avoided, try utilizing a larger battery. Partial discharge on Li-ion is fine; there is no memory and the battery does not need periodic full discharge cycles other than to calibrate the fuel gauge on a smart battery.[/FONT]
Hope this helps.
