Help battery life today is crap...
vr4
no clue why. unplugged at 7am. down to 30% at 11am with less than average use. no new apps downloaded, nothing in my routine changed except i didnt use the phone as much due to being busy at work.
ill usually be at 50-70% by the time i get home around 6pm and i use the phone quite a bit.
the only thing i did different was turn off GPS when i realized the battery was being chewed for some reason. this was at 70% and 9am.
cant see battery usage due to the force close issue. the only thing i can find is voice commands sensor is at 100%? dont know if this is normal as i never looked at this screen before.
found this thread
Something is Eating My Battery Life TODAY - Android Forums
and it appears to be the same as my issue.
Turns out it was that voice command sensor. Battery normal today. Checked and the voice sensor shows 0 use.
Im having a problem similar to what was going on with yours... how do you check/ turn down the voice sensor?
