Battery life usage
Jeyd02
Android Expert
Uhm. I want to know something and its being bothering me...
For those of you who have the extended 2900mav battery. How long does it last with heavy usage and how long it takes to charge... Well in my part it seems that the battery is not lasting as expected tho i only got it recently. Ooh one more thing...is the mungen battery worthwhile?
When you started using the battery did you re-calibrate?
I didnt recalibrate when i started to use it. But by the second cycle i made the attempt to recalibrate but im quite confused about that. First i wiped battery stats by cwr and then i tried with battery calibration app. Didn't notice much change.. :(
Whe you did it did you charge the phone to 100%, ran the app, or in cwr or delete the batterystats.bin then unplug and let the battery die completely then charged it back to 100% and used it as normal?
do i need to let the battery die? And will that actually increase battery life?
Yes. And no It doesnt increase the battery life. It gives the phone a more accurate reading. Like it will get out of wack and the phone can say 15% or what whatever but then 5 seconds later die even tho it said you have 15% left or it can say you have 15% left but really you have 40%. But yeah let it die completely.Like shuts the phone off dead. Leave it off and charge it to 100% over night. Then the next day turn it on, unplug it and use it as normal
Uhm.. Just look i though. well thanks anyway!!
