The Seido 1750mah battery fits pefectly with the stock cover. That and a few tweaks here and there (turn off bluetooth or wifi when not in use, etc) and you should be fine.
True, battery life sucks. Get the X. Need a link to their forum?Is the battery life on this phone really as bad as reviews and some people say it is?
Trying to decide between X and Incredible, and everything I read says the X's battery is WAY better. Is this true...or propaganda.
No matter what anyone says the battery is on par with what you would get with ANY smartphone.
No, I jumped straight from the Captivate to the Incredible, and the latter had a noticeably shorter battery life. The 1750mah battery is about par for the course, and doesn't affect the phone's thickness.
I use both. Here's my extremely unscientific impression using similar apps and usage styles:
Droid X stock battery easily lasts me all day (8am-midnight), with 30%+ remaining when I go to bed at midnight and plug it in. On a heavy usage day it will be dying by 6pm.
Incredible with 1500mah battery is lucky to last me until 6pm before it's gone. It's even worse on the stock battery. Even on its best day it lasts until maybe 11pm before throwing out the 5% warning. On a heavy usage day, it's toast by maybe 2pm. It's amazingly bad and I don't know why. I ONLY use dark backgrounds (best for AMOLED) and no push services except for gmail.
, installed ATK, big help there,
NOOOOO!!!!!!!!!
Please, get rid of this. It seems like its working because you probably have a bad app. Download SystemPanelLite Task Manager - Android app on AppBrain so you can see what is running a lot and manage from there. Also, read this
Android Task Killers Explained: What They Do and Why You Shouldn't Use Them
I've noticed that when froyo came out the battery life was improved although the charging time was much longer. Since this last BS update that was sent out the battery is as it was previous to froyo, which equals shit!
