Battery life
goatt
I hope I didn't reinvent a wheel someone else has already made, but I was getting terrible battery life recently and I discovered that if you turn off both...
Setting --> Accounts & Sync --> Background data and Auto sync
it improved my battery HUGELY. In addition, I still get my Twitter feeds updated every hour via the Launcher pro widget which apparently overrides the functions listed above.
Hope someone finds this helpful!
..it beats the purpose of a smartphone.
Because of that ^^^ the suggestion is less a "tip" than it should be, so moved out of the Tips and Tricks sub-forum.
I save a bit of battery life by manually syncing at will, but turning off both autosync and background data does render the device something else. ;)
I have never had bad battery life I guess. I don't see what people are whining about. It is made to "stay connected" at all times. If you disable everything then why not go back to a dumbphone? I didn't mean that to sound bad I just don't understand since mine seems to work as intended.
