PhoneMan93
I was thinking it would be a good idea to start a forum about battery life. I was thinking people could post there estimated percentage per hour and tell how the keep it so low or find out how to keep it low. So post like this.
Root: (yes/no)
Custom ROM: (yes/no)
[If yes to those two which method did you use to root your phone and what ROM you are using]
Kernal:
Scripts:
And then any other additional information such as apps and etc.
Here's mine.
Root: Yes (shabby-oneclick)
ROM: Yes (shabbymod)
Theme: simple green 4.2
Kernal: kourmakernal
Script: None
Estimated percentage: 1.8 per hour on standby
Thanks in advance for post and helping others with battery life
Root: (yes/no)
Kernal:
Scripts:
Here's mine.
Script: None
