battery life?
eto
What is it about CM-7, and 6 that will increase your battery life?
I saw related posts above the new post message box, when I started this thread, about battery life sucking apps (VAMPAPPS?) that just kill the life of your battery.
Is there some kind of VAMPAPP list for the Huawei?
thanks eto
thanks eto
It's just that 2.3 (CM7) it's more efficient of an OS than 2.1 or 2.2
I have no idea about vampapps.
  • Like
Reactions: eto
ok cm6 is still an improvement over Froyo though correct?
also even if cm 7 uses more power than cm 6, it is still less of a battery drain than froyo, is that correct?
thanks all for the replies, eto
cm6 is Froyo and saves battery good, just less customization, and cm7 is Gingerbread with alot of features. ;)
but is cm6 exactly the same as froyo? I thought CM6 was CynaMods(sp) altered/improved version.
I believe I have 2.2(froyo) on my huawei
