Help battery life
locuno1
so i recently rooted and installed the one.three rom all is well with those but my problem i noticed is my battery life seems to drain faster then it use to and i don't really run any apps i only text. i use the go keyboard and occasionally get on facebook
Check to see if some thing is keeping you phone awake and not letting it sleep. If the phone stays awake all the time it will drain battery, or some thing GPS not getting a lock and continually trying to lock etc... I use "Bad Ass Battery Monitor" great app has a free version and a paid. This app will let you see what is using your battery as well which apps keep awake etc...just select app usage, then scroll down to time held awake, shows not only which app but for how long. I found out an app I had was keeping my phone awake basically all the time...got rid of the app problem solved.
https://play.google.com/store/apps/...=W251bGwsMSwxLDUwMSwiY29tLmdzYW1sYWJzLmJibSJd
