GuitarG20
Clueless Senior Member
What's your screen on time?
me? was about an hour and a half
I'd reiterate what gibbs says here about BetterBatteryStats. I got rid of my DHD becuase the battery life was shocking, When I moved to the One X I was suffering the same. After using the app I found the culprit and removed it and have seen a massive improvement. If I'd had this app on my DHD I may not have been so frustrated by battery on that. P.S. look at "Process/Since Unplugged" or set a custom reference point to see a league table of the most battery-hungry apps that you are using.Try putting the phone into aeroplane mode (which basically shuts down the data connection and phone signal) and see if you still get poor battery life.
If you do I'd suggest downloading BetterBatteryStats from the Play Store and see if anything is draining your battery.
If it doesn't show any app as being the culprit then I'd say the battery looks faulty.
Thanks El Presidente that would explain it. For the last 2 weeks I have been in a virtually no signal area, I didn't even think about that.![]()
Try switching to GSM only. I live in a poor signal area too, so when I'm at home, I have to switch to 2G only or my battery life is rubbish.
not really related, but do you know if it is possible to turn LTE off on the AT&T branded variants of the One X? My friend, who has a iPhone 4S gets 4-5 bars of 3G (HSPA+ i am assuming) and yet my phone insists on sticking to the 2 bars of LTE it can get in my room (trashing battery life in the process)
100% to 91% in just 15-20 mins ........
Is it normal??
I have purchased it 15 days back.......and not getting proper battery .....
Even if wi-fi, bluetooth ,gps are off and use data connection for around 20-25 mins.....the battery is drained fully after 9 hrs ..........
I didn't charged it fully before i started using fr 1st time....![]()
Actually i used data connection and browsed for 15 mins.......
And i am not using the phone constantly fr 9 hrs.....the screen time is just appx 50 mins....
