I use DS battery saver, the greenify module with the xposed framework. removed unneeded apps and widgets. and run powersave screen brightness when inside.
with everything stock? o;
Stock with extra toggles, and boot animation, you don't need a custom ROM or scripts to save battery.
Check out the per app dpi to get the xposed framework. the greenify is available on the play store. Also don't use task killers, they don't help. Killing a task that the phone is using causing the phone to reload it again actually wastes power.
