Battery Life
Can we get some posts on battery life people are experiencing?
Hard to say, as everyone's battery life will change based on their own usage and I'm only on Day 2.
But with everything turned on, WiFi, Google now, NFC, and no real power savings, I look to be a solid 24 hours at least with typical usage.
Here is my first 24 hours on a full charge. I was listening to music and surfing the net for a few hours last night so I bet it would have lasted longer. 7 Hours and 27 Minutes left with 10% battery seems nuts but it might be possible since my phone sat at 100% charged for 3 hours before it dropped down to 98%. I have been in the habit of setting my previous phone since I owned the Galaxy Nexus to Airplane mode to preserver battery life and not be interrupted with notifications.
Battery Usage
35 hours 54 minutes
Estimated Time Remaining
+ 7 hours 27 minutes
Last 3 hours in use
8% Use
Battery Usage
35 hours 54 minutes
Last 3 hours in use
8% Use
I bet mine would last much longer but I have everything turned on and my usage is pretty high.
Don't think battery life is anything to worry about with this phone.
I'm at moderately heavy usage, brightness on 100%, lots of texting, a few calls, bunch of web browsing, and I'm at 47% after about 9 hours.
My iPhone 5 would have been at about 65% on its second charge of the day.
You left us for an IPhone 5? Yuck. ;)
Thanks for all the input. Was just wondering if I could get through 12 hours without a charge. Sounds like it passes that mark with ease even with heavy usage.
I picked up yesterday. Last night I went to bed with the phone at 100% woke up this morning and it was at 50%? Something must've been sucking the battery dry last night and it wasn't the display. It said most was "Android System"
I hope it was just a fluke.
I'd give it a few charge/discharge cycles before becoming concerned.
With that said, a weak Data/WI-FI signal will suck down a car battery.If you continue to have less than stellar battery life check back in here w/more detailed information on what's running/downloaded on your phone.
Best battery life I have experienced in a smartphone since picking it up Friday the 13th. I'm using the LG G2 heavily and getting over a day per charge.
You will not be disappointed with the battery life. I took the phone if the charger and looked at the time. I set the phone down and went back to sleep and the phone stayed at 100% for 3 hours. The phone was idle but none of my phones have ever been able to do that.
I'm getting about 36 hours of heavy use. I have all sync turned off (including Google now) except for work EMail, it updates once per hour off peak times.
