And when you tap on the cell Stand by , what's it showing for time without signal?
My wife's will show 98, 99 or 100% w/o signal , meanwhile the battery is lasting forever, apps I put on it don't show any drops
I did that *#*#4636#*#* to load that testing screen , to see if gsm was turned off ( like the opt v fix) but the volt won't let you make any changes and it blocks half the info, I did see it said gsm for emergency calls only so it's probably set correctly (cmda auto prl) the old opt v would sometimes have gsm/cmda auto checked by accident
oh well if I find anything I be sure to post it for you, seems were the only 2 with this problem on this phone
let me know if you come across anything
Thanks again
Thanks again
