Help Battery Meter Showing a Question Mark
MikeTyson
Friend of mine said he activated a Droid today, brand new, and the battery meter is showing a "?".... No meter just the empty battery meter with a question mark inside of it...
Anyone have that issue or ever heard such a thing?:confused:
I had the same problem. I just removed the battery, and put it back in. All seems to be working now. Hopefully that solved it!
That's interesting, never had it happen to me but will store it, that way if it happens, I'll know how to fix it..
i had the same issue, read all the forums and tried everything. finally i put the battery only in the freezer away from water(lithium reacts with water) and waited 5 to ten minutes and then put the battery back in and plugged it in, pushed power on, and instant start up with 5% battery life already. try this and let me know the results. Thanks ahead for feedback. :D
