Help Battery must be running on Black Magic
MDesire2010
Member
I think my Battery just hit a turning point in its life.
For whatever reason I got exceptionally good battery life yesterday. I had it unplugged for 20 hours and it was only down to 52% Remaining by the time I was going to bed. Usually, I only get maybe 18-20 Hours with 10-20% left. My usage was if anything higher than usual too throughout the day. Listening to music/videos/texting/emailing/testing apps for a fair bit of the day.
The only thing I did differently that morning was unplug it like normal (when I woke up and it was at 100)%, then plug it back in about 10 seconds later for another 5 Minutes before heading out the door. Would that have caused this peculiarity in my battery consistency ??
Sometimes this fools it into charging the battery a bit more (100% isn't actually 100%, its less). Usually you have to power off to do this, but maybe it worked for you when on.
Try it again and see how long it stays at 100% for... When I calibrate in this way, I usually stay on 100% for what would normally be 5%. In otherwords, my battery is at 105%
I hope this is the case! It's a sweet little trick. I also should add that in my "Battery Use" the Android System was at 96% and Cell Standby was 2% and Phone Idle as 2%.
