Battery not charging
sgtch2
I dropped my Hero in the toilet clean water mind you for those wondering and have got it working except when plugging it in to charge the indicator shows its charging the app says everything is fine but it either stays and it current level or actually drains the power out. It worked once but if i shut it down and boot it back up it does worse. Help.....
Welcome to the Android Forums!
Had it been gone swimming just moments ago I'd have recommended that you pull the battery and put it into a bag of rice for at least a day to wick most of the moisture out. It sounds like, however, you've used it since dunking it. Under that circumstance I'd hope you have insurance because you may need it...
