gunsnroses
Member
when my battery was almost empty i started charging but after 30 mins when i removed from charge it was still in empty position.
did u try again? did the battery icon show that it was charging? did u try the wall socket charger and the USB cable both?
i too suffered with this kind of problem,
but rebooting the device solved this & i didn't suffered with such problem again
actually i didnt reboot but used phone in low charge and in sumtime it got switched off and when i started charging for now 16% has been charged in 15mins.
Leave it alone and do not use it for a while. The phone uses a good bit of power and using it while charging will take a while! The charger is not exactly over powered and it made to slowly charge you device over several hours.
