I have Battery Monitor and like it.
No not in default Jelly Bean, but i know that you can get an app like Battery Indicator, which puts a percentage on your status bar.
Otherwise you would need to root to get a percentage.
Well stock android is a no, but as already explained Samsung allows this, I know it is on the Galaxy S3 and the Note 2, not sure what phones before this had it on Touchwiz.
Settings/display/show battery percentage
Nice feature and stock android needs to get this in there as well.
it is also available on the T-Mobile S2
, , ,Instead of a tiny number inside the battery icon, it's a full sized number to the left of the icon. Much more useful.
Not sure why you would use that when the functionality comes stock on our device?
